Activity › Forums › Apple Final Cut Pro Legacy › Logging anomalies in FCP5?
  • Logging anomalies in FCP5?
    Posted by Wilhelm Beck on June 16, 2005 at 3:07 pm
    Hi there!
    I`ve experienced some logging anomalies in FCP5 which slows the logging process down in comparison with previous FCP-versions:
    – Hitting F2 does not anymore set both the outpoint and opens the log clip window prompt. It does opens the correct dialog-box but it does not set the oupoint! Before I discovered this I only captured the first frame after the inpoint!
    – When navigating via timecode in the current timecode field (I
    Josephine Healey replied 21 years, 3 months ago 2 Members · 3 Replies
  • Josephine Healey
    June 16, 2005 at 11:19 pm
    Have you tried the usual? Dumping prefs etc. I’ve been logging a lot and these commands have been working fine for me. What is your system setup? OS and QT?
  • Wilhelm Beck
    June 17, 2005 at 8:09 am
    Thanks for replying Josephine,
    The pref
  • Josephine Healey
    June 18, 2005 at 1:16 am
    Your prefs are under
    USERS-YOU-LIBRARY-PREFERENCES
    in there you will find a com.apple.finalcutpro.plist You can dump that
    and then a Final Cut Pro User Data folder
    in that folder dump everything that’s not in another folder
    all should be prefs and caches.
    Hope this works for you.
