Activity Forums Apple Final Cut Pro Legacy logger keyboard shortcuts
  • logger keyboard shortcuts
    Posted by Rick Dolishny on May 20, 2005 at 10:11 pm
    I’m manually entering a longish log and am tabbing along … but is there a way to skip over “scene” and “shot/take” and the two little clock fields on the top and go straight to TC in and TC out?
    My desired tab order would be:
    reel
    description
    tc in
    tc out
    F2
    – Rick
    Bret Williams replied 21 years, 4 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    May 21, 2005 at 1:14 am
    Might consider logging in excel… that way you could just setup the necessary fields. But don’t think there’s a tab way to do what you want… you could actually mouse there though.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Bret Williams
    May 21, 2005 at 5:24 am
    FCP has had a severely crapping logging system since day one. Especially for doing what you are doing. But I found a good workaround that only means touching the mouse once each clip, and never moving it. Except when changing reels. I assume you’re entering all the clips for one particular reel, then moving to another? If not, maybe you can adapt this.
    1. Enter the reel
    2. mouse click on the TC in field (leave the mouse pointed there)
    3. enter the in
    4. tab once to the TC out field and enter the out TC
    5. press F2 (log) and it will ask you for the description, type it in
    — side note, if you have a repetitive description, you can copy it, and then paste it after each F2, then adjust —-
    6. click the mouse and you’re back at the TC in.
    So except for the 1 mouse click, it operates like Avid or Media 100 logging, instead of the idiotic tabbing through fields like duration, take, scene, etc
