Activity Forums Apple Final Cut Pro Legacy Logged Clips Not In Bin….and then error
  • Logged Clips Not In Bin….and then error
    Posted by Mark Crews on July 10, 2009 at 2:12 pm
    I am trying to capture some DV footage through firewire from a Sony Deck. This has worked before, but now the clips do not go into my bin. They go into the proper folder on my capture drive, then if I try to drag them into the bin I get “File Error: Unknown File” The clip plays fine in Quicktime Player. The codec I am using is DV/DVCPRO – NTSC. I also tried to drag in clips from early captures but I get the same error.
    Mark Crews
    FCP 5.0.4
    OS X 10.5.7
    Rafael Amador replied 17 years, 1 month ago 2 Members · 2 Replies
  • Mark Crews
    July 10, 2009 at 3:22 pm
    I re-installed FCP and seems to be working fine now.
    Mark
  • Rafael Amador
    Hi Mark,
    Probably this is not the reason of your problems, but i think that FC 5..4 will be more happy with Tiger than with the last version of Leopard.
    Cheers,
    rafael
    http://www.nagavideo.com
