Activity Forums Apple Final Cut Pro Legacy Log & Transfer problem with JVC Everio
  • Log & Transfer problem with JVC Everio
    Posted by Juha Västi on May 24, 2011 at 4:16 am
    Hey,
    I have this weird “Log & Transfer” problem with JVC Everio in Final cut pro. Everything is fine when i start the Log & Tranfer and then transfer sotps at some point and final cut pro does not report any problem. I have allso Panasonic camera (ag-af101) and with it the transfer works fine. With both cameras i use USB cable (Tryed to change it)
    The orginal file lenght could be something like 44minutes and the tranferred file is something 1-30minutes. I had the same problem last time. Then i used windows defrag and manage bearly to get the files out. I can copy them out…but then i need a way to convert EVERIO MTS files to ProRes 442.. I tryed MPEG Streamclip but it tells me the files are unsupported.
    I have newest final cut pro and MPEG Streamclip. I have Mac pro dual quad…
    When i use VLC player or Log & Transfer or cameras preview the videos works fine.
    Rafael Amador replied 15 years, 4 months ago 2 Members · 1 Reply
  • Rafael Amador
    May 24, 2011 at 8:43 am
    Hi Huja,
    I have an Everio and no problem for L&T.
    Your issue may be on the files length, not sure.
    Clip-Wrap will let you transcode the MTS files.
    Rafael
    http://www.nagavideo.com
