Activity › Forums › Apple Final Cut Pro Legacy › Log Transfer on Scratch but not in Project
Posted by Michele Vee on May 4, 2010 at 1:19 amI logged and transferred 3/4 of my media and got the Spinning Ball so I had to Force Quit. When I reopened project only 4 clips of the 25 showed up in project (I saved often enough). So after nearly fainting, I checked the Scratch disk and all clips are there in .mov files. Do I now have to Import into my project? Are they now considered individual files that no longer have continuous timecode? When I played them as movies they seem self contained? I have 2.66 Quad Core Mac with 650 GB HD–125 G’s left and 6 G RAM. Help?
MVMV
Doug Beal replied 16 years, 5 months ago 4 Members · 9 Replies -
Shane Ross
May 4, 2010 at 3:23 am[Michele Vee] “Do I now have to Import into my project?”
Yeah, but that’s EASY. Just FILE>IMPORT, or drag from the location into the project. What happened is that the program crashed before the project had a chance to be saved.
[Michele Vee] ” Are they now considered individual files that no longer have continuous timecode?”
No…well, yeah…well… They are individual QT files. That’s normal. They will have the same timecode as they do on the tape…they will be the same as if the program didn’t quit.
[Michele Vee] ” When I played them as movies they seem self contained?”
They are. They were separate clips in the project, no? You said you had 25 separate clips…do you not have 25 separate Qt files?
Shane
Read my blog, Little Frog in High Def -
Michele Vee
May 4, 2010 at 2:01 pmThank you Shane! Everything you said worked. I am a bit worried still re: crash syndrome. I specifically bought a new Mac to “handle” hi rez video import & editing and was shocked that it was laboring so much during two simultaneous tasks: ingesting & playing back so I could log. (Any secrets re: why the J,K,L’s don’t work during log & transfer?)
Long day after a shoot and then kaboom so thanks much.
MVMV
Shane Ross
May 4, 2010 at 4:30 pm[Michele Vee] ” (Any secrets re: why the J,K,L’s don’t work during log & transfer?) “
It isn’t designed to? That’s all I know. Yes, it is annoying.
Shane
Doug Beal
May 4, 2010 at 10:39 pmwhen you say you have 650 Gig left
I’m hoping your are not capturing to your system drive. You have the drive you are capturing to as a separate drive correct?Doug Beal
Editor / Engineer
Rock Creative Images
Nashville TN -
Michele Vee
May 5, 2010 at 12:10 amI used to keep my media on an external drive but when I got the new quad core, Apple FCP guy said that the whole point was to keep the media on system HD so computer wouldn’t have to constantly retrieve from external drive which is slower. He said that’s why they have the new quad core so you can just add more internal drives 1-2T at a time. Rut Roe…should I not have listened?
MV
David Roth weiss
May 5, 2010 at 12:39 am[Michele Vee] ” Apple FCP guy said that the whole point was to keep the media on system HD so computer wouldn’t have to constantly retrieve from external drive which is slower. He said that’s why they have the new quad core so you can just add more internal drives 1-2T at a time. Rut Roe…should I not have listened?
“Michele,
You’re using system drive and internal drives interchangeably. You can certainly add 2Tb media drives internally in addition to your system drive, but capturing to the system drive where your applications and the OS are stored is absolutely a no-no.
The reason the Apple guy said the additional internal drives were faster is because he meant faster than external firewire drives, because SATA drives are indeed faster than even single firewire 800 drives. That’s the only thing faster about them, there’s nothing inherently faster about them because they are internal.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
EPK Colorist – UP IN THE AIR – nominated for six academy awards
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
Michele Vee
May 5, 2010 at 2:28 amYikes shame on Appleman–he specifically said to put the media on those drives because now, “it won’t have to go looking for them”…Thanks so much…will get external drives now. Can I move the media and just “reconnect to media”? If I do that, will FCP automatically made a new Scratch folder?
MV
Michele Vee
May 5, 2010 at 2:35 amOh wait, I got it…I should put media on subsequent internal drives (I don’t need to buy external drives) and not my main drive. (I only had the 650 G drive when I bought it which is where he said to put the media.) Can I move the media and just “reconnect to media”?
Again, thanks so much for catching this…I asked a million times because it was the first rule I learned to always keep the media on an external drive.MV
Doug Beal
May 5, 2010 at 3:17 pmThere ya go
Atttach 1 or more Sata3 drives to the carriers and slide them in, copy, and reconnectDoug Beal
Editor / Engineer
Nashville TN
