Activity Forums Apple Final Cut Pro Legacy Log & Transfer from HVX footage incomplete. Sad!
  • Log & Transfer from HVX footage incomplete. Sad!
    Posted by Jennifer Bennett on August 10, 2009 at 9:35 pm
    I spent my entire weekend shooting some animation footage with the HVX200. I shot in 720P/30P. Everything played properly in the camera. I am having difficulty getting the footage into Final Cut Pro. When I log and transfer, the clips play perfectly fine in the preview screen. When I drag the clips to the timeline however, they do not play in their entirety. For example, an 8 second clip in the transfer preview screen is only a two second clip in the timeline. It goes through all the motions of transfering it – I get the spinning arrow and a filled in dot next to the clip. I apologize that I don’t know all the techinal terms. If anyone has an idea what I can do to save my footage I would greatly appreciate it! I am a bit heartbroken about it!
    Jennifer Bennett replied 16 years, 9 months ago 3 Members · 4 Replies
  • Shane Ross
    August 10, 2009 at 9:46 pm
    Well, DVCPRO HD 720p is a 60 frame format. So if you shot 8 seconds it might have imported as…well, I would expect 4 seconds….but you said two? How about going into the Log and Transfer prefs and unselecting REMOVE PULLDOWN?
    I don’t have experience shooting stop motion and importing, so…take that as you may.
    Shane
  • Jennifer Bennett
    August 10, 2009 at 11:54 pm
    Thanks for your speedy response! I will give that a try. I don’t think my footage is messed up because it plays in the camera and in the transfer preview menu correctly. I think the problem is just getting it to mesh in FCP. I was never very good at the technical details! I guess I have a lot to learn! The strange thing is that not all the clips were incomplete transfers. There were a few that went into the timeline perfectly fine and they had all the same settings. I will keep trying!
  • Mike Schrengohst
    August 11, 2009 at 6:31 am
    Forget Log & Transfer
    Get: Raylight for MAC
    https://www.dvfilm.com/raylight/mac/index.htm
    You can scan an entire CONTENTS folder in seconds and start editing….
    I have not used Log & Transfer – well – hardly ever….
  • Jennifer Bennett
    August 13, 2009 at 1:39 am
    Thank you Thank you Thank you! I unselected “Remove Advanced Pulldown and Duplicate frames” and everything worked! I really, really appreciate it!
