Activity Forums Apple Final Cut Pro Legacy Log & Transfer can see clips but cant pull in
  • Log & Transfer can see clips but cant pull in
    Posted by Jake Wheeler on September 25, 2007 at 11:34 pm
    I posted before about FCP 6 not recognizing my MXF files for import. After changing a folder name to “contents”, FCP now reads the files in the log and transfer window, and I can see and scrub the footage, but I still cannot import. I get the red exclamation point after it times out.
    This is my first time doing this, are there any simple troubleshooting steps? The lastclip file is missing, but I can still see and scrub thru the clips in the window. any thoughts on what could be wrong?
    thanks much
    jake
    fcp 2
    g4 2×1.25
    hvx 200
    Joe Linton replied 18 years, 7 months ago 3 Members · 2 Replies
  • Shane Ross
    September 26, 2007 at 12:02 am
    HOver the mouse over the exclaimation point…what error does it say occurred?
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Joe Linton
    January 31, 2008 at 5:30 am
    Hi Shane,
    I have been having similar issues with importing P2 as well. I can view the files, play them, log them, etc. I can even import files under 2min with no problem directly to my logging bin. My problem occurs if I try to transfer a clip that is over 3min in length, I get a red exclamation point with the rollover message “error: unknown” and the clip doesn’t import into my bin, nor my scratch disk.
    I don’t have FX Factory’s plugs installed (thank you for your thorough testing on that!) but I am running FCP 6.0.2 & QT 7.4 on OS X 10.4.11, which as I am finding out by reading the past couple of hours, has problems with P2.
    I am currently on a road job, logging & editing interviews for a huge corporate event and any advice that you can give me would be greatly appreciated. Thank you.
    Best,
    Joe Linton
