Activity Forums Apple Final Cut Pro Legacy Log & Capture problems with FCP5 & Canon
  • Log & Capture problems with FCP5 & Canon
    Posted by Andrex71 on December 20, 2005 at 2:06 pm
    hi everybody,
    i’m using FCP502 on a dual G5.
    It’s everything ok if i Log&Capture connecting a Sony HC90 but, when i connect my Canon XL2 or XM2 it happens as follows :
    i got “VTR OK” in the Log&Capture window, i can control the tape in the camera but i got “Preview disabled” message when i push the play button and also if i try to push the capture now button it appears a black video and, after a while, the message ” this operation could not be completed as there is no video ”
    any suggestions please ?
    Csabot replied 20 years, 7 months ago 5 Members · 7 Replies
  • 7 Replies
  • Bouncing Account needs new email address
    December 20, 2005 at 2:30 pm
    The obvious suggestion is to only capture using a camcorder that works.
    Canons are notorious for problems regarding their non-standard audio sampling rates, but not to the point of “unusablity” as you describe.
    But, as above, why not just put the tapes in a camcorder or deck that DOES work with FCP and capture from that?
  • Andrex71
    December 20, 2005 at 2:37 pm
    sure Matte, for the moment i’m doing that way but, since i have to sell my sony ( which, at the moment is the only way i have to capture ) how will i capture my dv tape recorded with the Canon XL2 50i 16/9 in the next days ? Is it possible that such a camera can’t work propely with Mac and FCP5 ???
  • Boyd Mccollum
    December 20, 2005 at 4:49 pm
    Andrex, folks can and do capture with the canon. Search the posts here (or at lafcpug.org). Double check your a/v capture presets and sequence settings to be sure they match your camera.
  • Jack Fox
    December 20, 2005 at 4:56 pm
    How exact do I play it from the timeline and what do I use for countdown and slate?
    jmf
  • Jack Fox
    December 20, 2005 at 4:59 pm
    As to AV settings what should I be using for Compression “DV/DVCPRO – NTSC.” I am using my DVX100 as a deck.
    jmf
  • Csabot
    January 25, 2006 at 4:39 pm
    Hi – Did you ever solve this problem? I am having the exact same symptoms on FCP 4.5 – only it is effecting any capture source i try. Any suggestions you may have base on your experience would be greatly appreciated.
    Take Care and thanks…
  • Csabot
    January 25, 2006 at 8:31 pm
    Nevermind – I found the solution on this forum – my problem was related to an upgrade to Tiger –
    https://forums.creativecow.net/cgi-bin/new_read_post.cgi?univpostid=873995&forumid=8&postid=873995&pview=t
