Activity › Forums › Apple Final Cut Pro Legacy › Log & Capture out of synch
  • Log & Capture out of synch
    Posted by Duncan Mcdade on August 10, 2008 at 6:07 am
    Whenever I use log and capture and the sound is out of synch, it always seems to be 21 frames out. This seems to be irrespective of the deck used, although all have been 50i or 25P. Its easily fixed by recapturing the tape, but I was just wondering if anyone knew why its always 21 frames?
    Arnie Schlissel replied 18 years, 1 month ago 3 Members · 2 Replies
  • Andy Mees
    August 10, 2008 at 1:45 pm
    apologies if I missed the earlier details regarding the specifics or your system, i/o and capture method, but it would seem that you either have an issue with the signal path getting into FCP, or when monitoring the captured footage after the fact ? just a thought given the symptoms
  • Arnie Schlissel
    August 11, 2008 at 5:55 pm
    [Duncan McDade] “Whenever I use log and capture and the sound is out of synch, it always seems to be 21 frames out.”
    It sounds like your speakers are not connected to your capture card. You FCP manual has a series of diagrams that show how to connect your video monitor & speakers to in a variety of setups. Check the manual to see how to connect your speakers properly.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
