Activity Forums Apple Final Cut Pro Legacy log & capture isn’t working
  • log & capture isn’t working
    Posted by Jason Noto on May 17, 2006 at 3:59 pm
    my log & capture image is coming up as static, and does not display the image that i am seeing in my monitor regardless what tape i am using. it was working okay yesterday, and i do not believe any setting(s) were changed. is there a setting i might have better luck with? etc.
    Thanks. I appreciate any insight and info you are able to share
    Jason
    Tom Matthies replied 20 years, 4 months ago 4 Members · 3 Replies
  • Michael Hoffman
    May 17, 2006 at 4:42 pm
    Often this comes about due to a quirky quicktime installation or a corrupted FCP preference.
    If the camera captures in iMovie, you know that it is ok and computer and camera can communicate.
    If that is the case, try the quicktime reinstall>
    Go to /library/receipts and delete any files that say Quicktime followed by a number e.g. Quicktime703.pkg
    Go to the Apple quicktime site and download the appropriate version of Quicktime to your hard drive.
    Run the Quicktime installer.
    Repair Disk Permissions for your System Disk (Disk Utility > Select the system disk > Repair Disk Permissions)
    Reboot
    Good luck.
    x
  • Todd Beabout
    May 17, 2006 at 4:53 pm
    I’d trash your FCP preferences first before the QuickTime re-install. Do you get the “Preview Unavailable” over color bars in your capture window?
    -Todd Beabout
    Vazda Studios
  • Tom Matthies
    May 17, 2006 at 5:14 pm
    Just a thought.
    Your profile doesn’t list how you are capturing video, but make sure that you aren’t trying to capture SDI video through an analog input. On many analog monitors, SDI video can look a lot like static.
    Might be worth checking your capture presets.
    Tom
