Activity › Forums › Apple Final Cut Pro Legacy › Log & Capture HDV as Pro Res OR just set render tab to Pro Res after the fact?
  • Log & Capture HDV as Pro Res OR just set render tab to Pro Res after the fact?
    Posted by Lisa Rolley on February 21, 2009 at 1:47 am
    Hey Friends,
    So this is for a doc which has something like 80-120 HDV tapes worth of footage so my question is if it makes more sense to just capture the footage as Pro Res OR just set the render tab format to Pro Res and do it that way.
    What should I be aware of and what things do I need to know.
    Thank you anyone who has some thoughts on this to share : )
    thanks
    Lisa
    Rafael Amador replied 17 years, 4 months ago 3 Members · 5 Replies
  • Rafael Amador
    February 21, 2009 at 5:33 am
    Hi Lisa,
    There are different opinions about what is more convenient, but I don’t see the point of capturing ProRess unless you will edit with few layers in a no much powerful machine.
    I work with EX-1 (very close to HDV) and normally I edit native. When my sequence is ready to export, I change the codec to ProRess and set “Render all YUV material in High Precission YUV”.
    You have another option that is edit HDV and when your time line is done, recapture as ProRess only your sequence. Better than capturing 120 tapes as ProRess.
    Don’t forget another intersting option that FC offers, that is editing in HDV but render to ProRess.
    This option is only available when working with EX-1 or HDV footage.
    Cheers,
    rafael
    http://www.nagavideo.com
  • Lisa Rolley
    February 24, 2009 at 3:58 am
    hey raphael
    thanks for the response – the last option is what i was goign with and am just going to stick with that. in that its a long form doc i guess what u are saying is that i should only change the render tab to pro res when its time to render out a final locked edit…
    thank you
    Lisa
  • Rafael Amador
    February 24, 2009 at 4:27 am
    Hi Lisa,
    The thing is to make the editing as easy as possible and set FC to his best quality only right before export the master.
    Rafael
  • Andreas Wappel
    May 17, 2009 at 12:15 pm
    hi,
    is this about changing the render-options in the user settings? and if so, what difference does it make for the final export of the project if the render-files are ProRes instead of the native codec?
    mfg
    aw
  • Rafael Amador
    May 17, 2009 at 2:43 pm
    Hi Andreas,
    Setting “Render to ProRess” have a little problem: When you export you are not exporting to ProRess but to the sequence codec. The render files are for nothing.
    I prefer set the sequence as Proress. When you export, you export the already rendered files.
    rafael
