Activity Forums Apple Final Cut Pro Legacy Log & Capture From Hard Drive
  • Log & Capture From Hard Drive
    Posted by Deepblue7600 on April 20, 2005 at 7:57 am
    I want to do a shoot and capture it in 10BUC directly from the camera to Hard Drive via SDI and an AJA IO. Is there a good way to effectively log and capture clips from the resulting, very long QT file as you would from a controllable deck? I’m trying to avoid having to store the entire shoot (long clip) on my array?
    I have tried using sub clips, but so far, it still requires that the entire footage remain on my array.
    Anybody know a good way to solve this?
    Thanks and regards,
    Eric
    Deepblue7600 replied 21 years, 4 months ago 2 Members · 2 Replies
  • Tom Wolsky
    April 20, 2005 at 11:56 am
    Make your subclips. Toss the ones you don’t want. Then run it through Media Manager to copy it to a new project, deleted unused media. That’ll give you QT files of just your selects.
  • Deepblue7600
    April 20, 2005 at 8:53 pm
    Thanks for your input Tom.
    Your suggested method of using Media Manager to create a new project with subclips solves one of my dilemas. However it does not seem like it will facilitate recapturing of media if I wanted to rebuild and edit the project at a later date. Or do you have a solution for that also?
    Regards,
    Eric
