Activity Forums Apple Final Cut Pro Legacy log & capture
  • Posted by Sarah Lewis on October 13, 2010 at 12:33 pm
    Hi
    I am ‘log and capturing’ 30 hours of footage onto FCP. FCP is creating a new file everytime the camera was turned off and on when filming – often this is up to 50 different shots per tape and I would much prefer to have only a couple of large files per tape. In the prefs I have deselected ‘report dropped frames during play back and ‘abort capture on dropped frames’ and selected ‘warn after capture’. Does anyone have any idea how I can change the prefs or what to do to capture all the footage in a large file?? Any help would be much appreciated.
    many thanks
    Sarah
    Sarah Lewis replied 15 years, 10 months ago 4 Members · 6 Replies
  • Trevor Ward
    October 13, 2010 at 1:46 pm
    Two questions before you can get an answer:
    1. Are you using Firewire to capture (from either a camera or a deck)?
    2. Does your tape have time code breaks?
    -trevor ward
    Red Eye Film Co.
    http://www.redeyefilmco.com
    orlando, fl
  • Sarah Lewis
    October 13, 2010 at 1:56 pm
    Yes, I am using firewire from a Sony Z1 camera and NO I don’t have any timecode breaks in tapes – it just seems to log each separate shot as a new file.
    Sarah
  • Jeremy Garchow
    October 13, 2010 at 2:14 pm
    What format are you capturing?
  • Trevor Ward
    October 13, 2010 at 2:20 pm
    Hmmm. I don’t know then. I know iMovie does that sort of thing, unless you uncheck an option box. I didn’t think FCP did that.
    Have you tried logging your clips first, then doing a batch capture? Or are you using Capture Now?
    -trevor ward
    Red Eye Film Co.
    orlando, fl
  • Michael Gissing
    October 13, 2010 at 9:13 pm
    In Log and Capture with HDV, there is a little check box in one of the tabs to enable a new clip on camera stop starts. Uncheck this if you want to capture long clips
  • Sarah Lewis
    October 14, 2010 at 6:24 am
    Thanks so much – I think that may have solved it.
