Activity Forums Apple Final Cut Pro Legacy log and transfer/window does not show
  • log and transfer/window does not show
    Posted by Suzin Daly on December 8, 2009 at 7:42 pm
    I have no problem using log and transfer with my SD cards. But what’s driving me crazy is the window where you can play the clip, use in and out points does not show. I thougth maybe I needed to grab the little tab, move it over to expose the window with information. There is nothing to move. I am not sure if there is a set up I need to do? I am sure there is something I’m missing. I would like to see if I can sort this out if possible.
    Tom Wolsky replied 16 years, 8 months ago 2 Members · 5 Replies
  • Tom Wolsky
    December 8, 2009 at 8:24 pm
    You can pull the separator bar to the right to remove the window. It’s tricky though to get it to come back. Try double clicking on the right hand edge. You should be able to grab the edge of the window and pull it back. If all else fails trash your preferences.
    https://www.fcpbook.com/Misc1.html
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
  • Suzin Daly
    December 9, 2009 at 12:58 pm
    double clicking worked, the window came up, however, the log location is now gone and a double click or drag does not return it.
    when I closed down and started log and transfer again, just the window comes up.
  • Tom Wolsky
    December 9, 2009 at 2:01 pm
    As I said you can drag the edge and the separator, but they’re very sticky. Did you trash your preferences? That will reset the window.
    All the best,
    Tom
  • Suzin Daly
    December 9, 2009 at 4:54 pm
    It was sticky as you said, but I got it and what also helped is when I dragged the lower right corner to make it slightly bigger. Why that helped, have no idea. Thanks you
    On another note, I learned FCP from your Complete Training for FCP 6. I have become a big believer in DVD training, if I can see it, I can do it.
  • Tom Wolsky
    December 9, 2009 at 6:20 pm
    Glad to hear that. Thank you.
    All the best,
    Tom
