Log and transfer problems with 170 into Final Cut 6.0.1
Ok… I’m breaking down and asking for help.
I’m shooting on the Panasonic 170 onto P2 cards.
Editing on Final Cut Pro 6.0.1.I’ve done this a million times before and have had no issues.
My job purchased new gear (same gear but new) and I have an issue.Shot footage onto the P2 cards. 720p24. I can see the footage on the cards and play them in the log and transfer window.
When I drag the clips to the queue and start transferring, the queue pauses and a red exclamation point appears. I read a few blogs and tried to uncheck the “remove advance pull down” and same thing. That darn red exclamation point.
PLEASE HELP! I also have CS5 on my computer, but I only know how to edit in final cut. So worst case, I guess I can import and transfer footage in premier, but I still need to import them into final cut for editing. And either way… Im a loser because I don’t know premier.
Any help is much appreciated
Rebecca
