Activity › Forums › Apple Final Cut Pro Legacy › Log and Transfer Problems AVCHD
  • Log and Transfer Problems AVCHD
    Posted by Robert Mcintosh on July 26, 2011 at 3:39 pm
    Hi All,
    I’m having some problems trying to get some clips off a Panasonic HDC-SD10 on to FCP using the Log and Transfer option in FCP 6.0.1.
    I’m able to view the thumbnails for all the clips in the left hand pane and it accurately shows the time lengths of each clip. However, they will not play in the preview pane on the right and it just remains black. When I try and add them to the queue, it appears to do something for about 5 seconds and then a red exclamation mark appears and a tooltip says ‘Error: No Data’.
    I have read a few other posts about this, but the ones with solutions are all relating to FCE.
    Robert Mcintosh replied 15 years, 2 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    July 26, 2011 at 6:40 pm
    I could be wrong about this, but I’m pretty sure you need to update your version of FCP 6 to the last version of it to get AVCHD files to work right in Log and Transfer.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Robert Mcintosh
    July 27, 2011 at 11:45 am
    I will give that a try and let you know – thanks!
