Activity Forums Apple Final Cut Pro Legacy Log and Transfer Problem
  • Log and Transfer Problem
    Posted by Ben Smallzman on March 26, 2011 at 7:17 pm
    I cant log and transfer any clips at all. My Nikon S8100 doesnt get recognized in the log and transfer window, so i imported the clips into iphoto and then tried dragging the clips into the L&T window. but it kept saying, “contains unsupported media or has an invalid directory structure. Please choose a folder whose directory structure matches supported media.” After that, i converted the clips to Apple Prores 422 via Compressor, and then tried dragging those into the L&T window. the same messafe popped up. so clearly, i cant get any clips into the log and transfer window. Can anyone help?
    Thank you
    Ben Smallzman replied 15 years, 5 months ago 3 Members · 4 Replies
  • Steve Eisen
    March 26, 2011 at 9:23 pm
    You found out the hard way that you can not log and transfer files from that camera. Not all cameras are supported.
    You have 2 options. Use Compressor or MPEG Streamclip to convert to ProRes.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Ben Smallzman
    March 27, 2011 at 1:43 am
    i had already used Compressor to convert the clips to prores 422 and these still did not work.
  • Shane Ross
    March 27, 2011 at 2:21 am
    After you convert to ProRes, you DO NOT need to use Log and Transfer. Just import them.
    Shane
  • Ben Smallzman
    March 27, 2011 at 12:03 pm
    oh ok, thank you
