Activity Forums Apple Final Cut Pro Legacy Log and Transfer MXF files from external Hard Drive
  • Log and Transfer MXF files from external Hard Drive
    Posted by Digital Antics on May 19, 2011 at 8:11 am
    I am having a hell of a time ingesting a days worth of P2 footage, shot on the HVX200, that we copied(content folder and last text clip) to two external G Tech drives; while on set. It is giving me the unknown source/directory warning when I try and select a folder with the .XMF files in it while in the Log and Transfer window. I am pretty sure everything is there since we did a straight copy. Does anyone know what I am doing wrong? Also when I try and import the .XMF files directly to the project bin they are all out of order and only 29secs of each clip appears. Any clue what I am doing wrong here? Any idea how I can rebuild the clip in FCP? Help, please. I am using FCP 7.
    Una Morera replied 15 years, 4 months ago 3 Members · 2 Replies
  • Cody Walters
    May 19, 2011 at 10:13 am
    [Digital Antics] ” It is giving me the unknown source/directory warning when I try and select a folder with the .XMF files in it while in the Log and Transfer window”
    Are you selecting the highest most folder that contains the content folder and last clip file?
    Cody Walters
    JW Studio LLC
    Houston Video Production
    Houston Wedding Videos
    Final Cut Studio 3
    Adobe CS5 Master Suite
    Panasonic HVX-200
    Canon 7D
  • Una Morera
    May 20, 2011 at 8:16 pm
    If you find out, please let me know, because I’m having the same problem! Thanks!
