Activity › Forums › Apple Final Cut Pro Legacy › Log and transfer missing clips
  • Log and transfer missing clips
    Posted by Martha Skolnik on September 8, 2009 at 3:01 pm
    I’m trying to log and transfer from P2 cards. Everything is going pretty smoothly, except occasionally FCP is not picking a file every now and then. Seems to usually be either the 1st or last clip of series. Anyone? Is there a workaround?
    Thanks, Martha
    Janet Baus replied 16 years, 8 months ago 3 Members · 2 Replies
  • Shane Ross
    September 8, 2009 at 5:38 pm
    Well, do you have some clips that say SPANNED? That means that the last clip from one card and the first clip from another are part of the same clip…so when FCP imports them, it joins them. In fact, you won’t see the first file on the second card because it is the second half of a clip on card 1…so FCP joins them.
    All is normal.
    Shane
  • Janet Baus
    January 11, 2010 at 6:16 pm
    I’m having the same problem. Log and Transfer does not import the second clip of the spanned footage, so that I am missing footage.
    I’ve tried just importing the spanned footage clip, but that doesn’t work either.
    Help! I’m on a deadline on a big project.
    Thanks!!!
    Janet
