Activity Forums Apple Final Cut Pro Legacy Log and Transfer cutting clips short on import
  • Log and Transfer cutting clips short on import
    Posted by Bret Sigler on August 12, 2009 at 8:32 pm
    I’m in the process of importing several 1080i 60 clips shot onto flash cards with the Sony z7u. I’m importing directly from the memory recording unit that comes with the z7u. Everything has been going swimmingly up to this point (I’ve successfully brought in 7 discreet clips ranging from 30-40 minutes in length), but I’ve finally hit a snag. The final clip I need to bring in is 00:01:07:00 in length, and for some reason each time I try to import, I only get the first 53 minutes or so of the clip. When the clip shows up in the log and transfer tool, it recognizes it as being an hour and seven minutes long, yet it will only import 53 minutes of it.
    I’ve searched up and down all of the FCP and log and transfer preferences (that I know of) to see if there is a setting somewhere that limits the length of imported clips, but I haven’t found anything. Thanks in advance for any ideas/suggestions …
    Laura Gamse replied 14 years ago 5 Members · 8 Replies
  • 8 Replies
  • Cole Prine
    August 12, 2009 at 8:56 pm
    In the log and transfer window you can set in and outs and import only what you’ve selected. Be sure to check that you don’t have an in and out selected.
    The only time I’ve ever had this problem was when I was importing RED footage. While it was importing, I was trying to organize footage that I had already pulled in. Apparently L and T doesn’t like this because it was pulling in several of the clips just like your situation – it wasn’t pulling in the full clip. Finally, I started the Log and Transfer and sat back, didn’t touch the computer until it was done. This worked for every clip I had trouble with. So, you may want to give that a shot.
    Cole
  • Bret Sigler
    August 17, 2009 at 2:32 pm
    Hmm … I’m not even able to modify the in/out points for importing this clip in log and transfer. I see the fields where you would be able to do that, but they both say “not set” and are sort of grayed out so that I can’t change them. I tried again to import the 01:07:16:00-long clip without anything else going on in the background, and I still only get 00:53:59:13 of it.
    Any other ideas?
    B.
    PS: did I mention that this is HDV footage shot to a flash card on the Z7U? I don’t think it matters, but I wanted to mention it …
  • Cole Prine
    August 17, 2009 at 4:03 pm
    Actually, it could be the drive your capturing too. I don’t remember the technical points, but if the hard drive you’re capturing too is formated a certain way, it will have a restriction of how big the file sizes can be. So, it may be formatted this way and because the clip is so big, it’s exceeding the size restriction. If you could set the in and out points, you’d be able to pull it in in two separate clips. Other than that, try setting another drive as your scratch disk.
    Someone else will have to tell you which hard drive formats have the size restrictions…or just search for it, I come across it pretty regularly here in the forums. Once you’re done with this project, you can reformat your drives so you won’t have this problem again. But wait until you’re done because it will erase the drive.
    Cole
  • Jack Norris
    March 29, 2010 at 9:38 pm
    I’m having the same trouble as you have indicated inporting from a Sony Hard Disk Drive. What was the ultimate solution you were able to achieve? Thanks in advance for your help
  • Jack Norris
    March 29, 2010 at 10:02 pm
    I’m loading from a Sony HDD and I have the same problem in that the clip is 40 minutes and the FCP only imports 16 minutes of it. Did you find a sloution to your problem that may help me?
  • David Roth weiss
    March 29, 2010 at 10:32 pm
    Your hard drive is most likely formatted from the factory as FAT32, which has a 4Gb file size limitation. You need to reformat the drive as Mac Extended (the non-journaled option) using Disk Utility. Be sure to move any files to another drive during the process or they will be erased.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    EPK Colorist – UP IN THE AIR – nominated for six academy awards
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Jack Norris
    April 1, 2010 at 7:31 pm
    Thanks for your help. Here’s what we did and here’s what happened:
    Using disk utility on our Mac
    We partioned/formatted the unit using the mac OS format as directed
    When we disconnected unit and strated the hard drive to hook up to the camera we got a 1201 error.
    This condition only allows one option to format the drive directly from the unit’s menu. When this is accomplished it is defaulted back to the DOS format.
    Do you have any other ideas?
  • Laura Gamse
    August 8, 2012 at 5:18 pm
    Just had the same problem. Convert with MPEG Streamclip & drag the files into FCP.
