Activity Forums Apple Final Cut Pro Legacy Log and Transfer crashes FCP
  • Log and Transfer crashes FCP
    Posted by Nate Mcneil on October 21, 2010 at 8:45 pm
    Recently I’ve encountered something strange in Log and Transfer. Whenever I try to mount a folder with File Based Media in it, Final Cut crashes and returns an “Unexpected error”.
    I’ve tried this on both XDCAM and P2 footage, from a variety of drives and it happens no matter what I try to load. I’ve also tried trashing preferences and all the other usual suspects to no luck.
    I’m hoping to avoid a full uninstall and re-install if possible. If anyone has any insight it would be greatly appreciated.
    Nate
    Nate Mcneil replied 15 years, 11 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    October 22, 2010 at 1:11 pm
    Is the folder on a hard drive or on the card that recorded it? I’d be sure to copy from the card to a hard drive for import.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    DVD:https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Nate Mcneil
    October 22, 2010 at 3:53 pm
    I’ve tried mounting data from an external SATA drive, from the tower itself, as well as RAID server, and they all encounter the same error.
