Activity Forums Apple Final Cut Pro Legacy log and transfer codec
  • log and transfer codec
    Posted by Thomas Clayton on June 30, 2010 at 9:09 pm
    I tried to log and transfer shots from my 7D compact flash card tonight. Unlike the previous times I have logged and transferred, FCP transferred as ProRes 4444 not 422. I couldn’t find any way in L and T to select a codec before transferring. The sequence is set for 422, render control in User Prefs is ‘Same as Sequence’ but I think that is for rendering the timeline.
    How do I tell Log and Transfer to import as Pro Res 422?
    Thomas Clayton
    Thomas Clayton
    MFA Student UNC Greensboro
    Thomas Clayton replied 16 years, 1 month ago 2 Members · 2 Replies
  • Shane Ross
    June 30, 2010 at 9:44 pm
    In the L&T window, in the upper middle, there is a SPROCKET menu. Click on that and choose PREFERENCES. In there you will be given the option as to what codec to transcode to.
    Shane
  • Thomas Clayton
    June 30, 2010 at 9:58 pm
    Shane,
    Since I am traveling in Europe I don’t know whether to say Gracias, Merci, or Danke. Please accept them all!
    Thomas
    Thomas Clayton
