Activity › Forums › Apple Final Cut Pro Legacy › log and transfer AVCHD to FCP
  • log and transfer AVCHD to FCP
    Posted by Arturo Celleri on August 2, 2008 at 8:39 pm
    I have a Sony HDR SR-11, and the latest version of FCPro operating on MAC PRO with OS X 10.5.4.
    I used log and transfer to bring up all of the video clips.
    I imported them (with audio) and converting audio to stereo.
    When I played the video’s back in FCPro, all of the audio was out of sync.
    Are there other settings that I need to set before importing to avoid this problem?
    Any idea how to prevent this?
    Arturo Celleri
    Arturo Celleri replied 18 years, 1 month ago 3 Members · 3 Replies
  • Todd Reid
    August 3, 2008 at 1:17 am
    don’t know if this applies, but if you had said you transferred P2 cards with this problem, I would have told you to check “remove duplicate frames” in the preferences. Not sure if AVCHD has this setting, but it was worth a answer as it may just solve your problem.
    If this is the case, you will have to retransfer all your footage.
  • Adam Schmidt
    August 4, 2008 at 2:05 am
    What do you mean by “Out of Sync”? How many frames? or did it start in sync and then loose sync after a few minutes?
  • Arturo Celleri
    August 4, 2008 at 3:21 pm
    I can’t tell how many frames it is out of sync, but it starts out of sync.
    I will check on the duplicate frame thing, and check my log and transfer settings. I don’t know much about this but I figure it must be a settings issue. Do you agree? Could you tell me what the settings should be?
    ARturo
    Arturo Celleri
