Activity Forums Apple Final Cut Pro Legacy Log and Transfer – Audio Only
  • Log and Transfer – Audio Only
    Posted by Josh Haggard on August 13, 2011 at 1:51 am
    I captured some AVCHD clips to Pro Res Proxy.
    Some clips I use only audio. When I media manage to LT those clips capture the unused video.
    I am media managing by:
    Selecting sequence > media manager
    Create Offline
    Delete duplicated media from selected clips
    Is there anyway to avoid this?
    I am aware there is an ‘Import Settings’ tab, but these seem only to have an effect when pulling clips directly from the AVCHD file.
    JH
    Jerry Hofmann replied 15 years, 1 month ago 2 Members · 1 Reply
  • Jerry Hofmann
    August 14, 2011 at 1:39 pm
    I’m not sure this would work, but maybe if you media manage only the video, then rebuild a sequence with the audio you already have? Not sure it would only transfer the video, but it’s worth a try?
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
