Activity Forums Apple Final Cut Pro Legacy Log and Transfer – 2 formats: GF1 and Canon 5D
  • Log and Transfer – 2 formats: GF1 and Canon 5D
    Posted by Douglas Gentry on July 5, 2011 at 8:16 am
    I have a mundane question and I’m sure there is a simple answer. I have footage from a Canon 5D (1920 x 1280, 25FPS).
    I have B-roll from a Panasonic GF1 (1280 x 720, 29.97 FPS).
    I would like to edit at Pro Res 422, 25 FPS.
    What is the best way to convert the 29.97 FPS footage? I will need a final output for both Vimeo and DVD.
    Is FCS Compressor the answer? Or am I over-complicating this?
    I’m very new to the FCP system, am excited about it, but am a bit confused after taking a few years off from editing!
    Thanks in advance!
    Douglas
    Douglas Gentry replied 14 years, 11 months ago 2 Members · 4 Replies
  • Chris Tompkins
    July 5, 2011 at 4:40 pm
    Edit in Pro Res 422, 25 FPS.
    Drop some of the GF1 footage into your 25fps sequence and see how it performs. Might not be a problem at all. Otherwise, ya run it thru compressor.
    Chris Tompkins
    Video Atlanta LLC
  • Douglas Gentry
    July 6, 2011 at 4:24 pm
    Chris,
    I’m just getting my head around FCP and Compressor in general, so I really appreciate the response.
    I was able to convert the GF1 footage to 25 FPS, Sq pixels, at 1920×1080 as a Quicktime movie. I can “drag and drop it” into the project, plays fine. Strange thing is that I can’t use log and transfer to bring it in. Is this the normal workflow? It would seem that log and transfer would be a more “normal” way to bring it in in case media goes offline, etc.
    Should I just drag and drop all of the media now that it is converted, or did I forget something wrong where log and transfer will not work properly?
    Cheers,
  • Chris Tompkins
    July 6, 2011 at 5:24 pm
    If you converted the GF1 footage outside of FCP. Then you should have mov files sitting on your hard drive. You do not L&T movie files. You just import them into you proj.
    L&T is for card media. There is a good tutorial here on the cow for working with tapeless:
    https://library.creativecow.net/ross_shane/tapeless-workflow_fcp-7/1
    Chris Tompkins
    Video Atlanta LLC
  • Douglas Gentry
    September 15, 2011 at 3:02 pm
    Cheers Chris!
    Douglas
