Activity Forums Apple Final Cut Pro Legacy log and transfer
  • log and transfer
    Posted by Suzin Daly on June 16, 2010 at 2:14 pm
    This is a first time
    Using Panasonic HMC 150, SD card
    I went to log and transfer – the clips did not come up on on the log and transfer list. All the clips show up in the camera and play with no problem. I put in another SD card that had some old clips to test out…they came up with no problem with log and transfer..I’m at a loss…any suggestions would be of great help.
    Suzin Daly replied 16 years, 2 months ago 2 Members · 4 Replies
  • Dan Monro
    June 16, 2010 at 7:05 pm
    No offense but, Are you sure the path to the media is correct? Maybe you need to go one step further in? I’m not familiar with the specific camera, but I’ve navigated to the wrong folder on many occasions…
    Dan Monro
    FCP, Avid, AfterFX, Atlanta
    MacBook Pro 2.4 GHz Intel Core 2 Duo 2 GB ram
    Mac OS X 10.5.8
    GeForce 8600M GT Final Cut Pro 6.0.6 Quicktime 7.6.4
    – OR –
    2 x 3.2 Quad Xeon; 16 GB ram
    Mac OS X 10.5.8
    NVIDIA Quadro FX 5600 Final Cut Pro 7 Quicktime 7.6.4
  • Suzin Daly
    June 16, 2010 at 7:15 pm
    No offence is ever taken. Log and transfer is similar to P2 card, DVX 200 – I tested log and transfer with another SD card, and it pulled the files right in and I could have added any clip to the Q.
    The clips play beautifully on the camera? I did find the information (like a hard drive showing up on the desktop) put still no go….It is a real puzzelment (I don’t know if I am having a dye my hair blond and move to L.A. or it’s a problem with the SD card)
  • Dan Monro
    June 16, 2010 at 7:27 pm
    And the folder structure on the “bad” card is the same as the one on the “good” card, right?
    Dan Monro
    Mac OS X 10.5.8
    – OR –
    Mac OS X 10.5.8
  • Suzin Daly
    June 16, 2010 at 7:32 pm
    It seems to be the same. However, because I am in learning mode, I am going to have my husband who is detailed oriented open up the files and go through them and match them to a good card. As of now I can’t see a difference. That is one of the things I tried to look at….I really do appreciate your input
