Activity Forums Apple Final Cut Pro Legacy Log and Transfer
  • Log and Transfer
    Posted by Chad Mackenzie on May 8, 2010 at 1:24 am
    So this is my current problem. My mac is currently not working, and the I’m using my friends Final Cut Pro.
    They don’t have the option for Log and Transfer option to get my footage off of HVX-200.
    What’s the link to get the Log and Transfer download??
    Already checked with panasonic.com and downloaded things for the p2 card, which…. did nothing at all.
    Chad Mackenzie replied 16 years, 4 months ago 2 Members · 4 Replies
  • Shane Ross
    May 8, 2010 at 4:19 am
    Log and Transfer is part of FCP 6 and 7. What version of FCP are they running? If FCP 5.0 or 5.1, then it is called IMPORT>PANASONIC P2.
    Shane
  • Chad Mackenzie
    May 8, 2010 at 5:10 am
    That makes sense. They have have 4.5. Is there a way to convert the files after ingesting them onto hard drive?
  • Shane Ross
    May 8, 2010 at 5:46 am
    FCP 4.5 is completely incompatible with P2. First version to support it was FCP 5.0.4. There are third party support options, but I am not sure if they will work with that old version.
    Raylight
    Calibrated
    MXF4Mac
    If you want to work with the latest format, you need to use a newer system.
    Shane
  • Chad Mackenzie
    May 8, 2010 at 5:47 am
    That makes even more sense now,
    thank you for the help!
