Activity › Forums › Apple Final Cut Pro Legacy › Log and Cupture
Log and Cupture
Posted by Jerry Luxik on December 26, 2009 at 2:47 amHow to capture DV video to HDV project.Thank you jerry
Shane Ross replied 16 years, 9 months ago 2 Members · 1 Reply -
1 Reply
Shane Ross
December 26, 2009 at 6:52 pmCapture DV as DV…via firewire using the DV/NTSC Easy Setup. You cannot capture DV as HDV unless you had a capture card…but then you wouldn’t want to capture DV as HDV as HDV is a very odd format, and you won’t want to CONVERT anything TO that format.
Want to mix HDV and DV? Edit in a ProRes HD timeline…you will have to upscale the DV manually.
Shane
