Activity Forums Apple Final Cut Pro Legacy Log and Capute / capture now DOES NOT WORK, it did in 4.5
  • Log and Capute / capture now DOES NOT WORK, it did in 4.5
    Posted by Zman on May 28, 2005 at 7:55 pm
    Ok we have installed FCP 5 on a Dual 1 gig that use to run 4.5 VERY WELL. no we are trying to capture from a sony DSR-V10 DVcam clam shell deck which always worked amazing in 4.5, now it will not batch capture or even capture now. we get the error page, all the setting are DV 48 across the board. any takers!
    Walter Biscardi replied 21 years, 4 months ago 3 Members · 2 Replies
  • Pete
    May 28, 2005 at 8:42 pm
    guess youve already done the prefs trashing?
  • Walter Biscardi
    May 29, 2005 at 1:30 am
    Are you running OS 10.3.9 or OS 10.4.1? 10.3.9 seems to be causing a lot of problems to a lot of people and I have avoided that OS.
    If you’re running OS 10.4, did you do a complete clean install and then install FCP?
    If you’re still trying to run OS 10.3.8 then that could be a problem with FCP 5.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
