Activity › Forums › Apple Final Cut Pro Legacy › Log and Capture won’t show video!
Posted by Hector Candleleven on August 11, 2005 at 11:00 pmI have a friend who wants to learn FCP. He bought a G5 and installed FCP on it. Everything works fine except for capturing footage. FCP won’t show video in the Log and Capture window. He can control the deck, but FCP won’t display an image on the window. I can create the same “problem” if I were to piggyback my deck off an external HD. BUT, he’s not doing that. He’s plugging straight into the Mac.
I’ve deleted pref files, changed settings, but still nothing. HELP!!!!!
Rob Forsythe replied 21 years, 1 month ago 3 Members · 4 Replies -
Josephine Healey
August 12, 2005 at 4:17 pmTry reading this and following instructions and see if it helps.
https://docs.info.apple.com/article.html?artnum=301852 -
Hector Candleleven
August 12, 2005 at 4:31 pmthx for the link. I forgot to mention that he’s using fcp4.5. Can I still use this solution?
Rob Forsythe
August 14, 2005 at 8:56 pmThis list contains about everything to try to enable:
a. External Monitor VIDEO and AUDIO via FireWire & DV deck or camcorder.
b. Viewing in the Canvas window on the computer screen.
c. Being able to record on the external FW DV deck or camcorder.Try things in this order until you find the “cure”:
1. Make sure you have only ONE (1) FireWire deck, camcorder, DV capture “card”, or D-to-A converter or video device attached to the computer at a time. Any more than one DV device can cause loss of signal and control.
2. Make sure you have View (Menu) > External Video> All Frames set.
(If the ALL FRAMES option is grayed-out… jump to step 6 below and continue.)
3. Make SURE your Canvas window (right window) in FCP is set to “Fit to Window”… AND that it has not been “pushed off” the edge of the computer screen.
4. Make sure your CANVAS View Menu (Box Icon with broken sides) is checked on Image or Image+Wireframe… NOT just Wireframe.
5. Make sure your CANVAS View Menu is checked on RGB… NOT just Alpha.
6. Make sure your Final Cut Pro (menu) > Easy Setup… is set for DV-NTSC (or DV-PAL, if that’s where you are).
7. Some camcorders/decks work better under “FW (NTSC/PAL)” -or- “FW (NTSC/PAL) Basic” control (in the capture settings). Try either setting to see which works best for your device.
8. Make sure your Final Cut Pro (menu) > Audio/Video Settings > A/V Devices (tab) > Mirror on Desktop > must be CHECKED. (If not, playing video will not appear in the Canvas.)
9. Make sure the “Log and Capture” Window is CLOSED and not just “hidden” behind other windows.
10. Turn off the power to the Camera/Deck/Converter Box, then turn it back ON.
11. Make sure the camera is in VTR mode… or the deck is in DV (DV, iLink, or FW) input.
12. On a Sony camcorder or deck, make sure the menu setting “A/V > DV Out” is set to OFF.
13. Re-check that your FW cable is well-connected at both ends (or try a new cable).
14. Important: Quit FCP, then Restart FCP.
15. Now again, make sure you have View > External Video > ALL FRAMES set…If it still does not work. “Trash” the FCP Preferences on the Mac
https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html“FCP Rescue” is a free Apple Script that will Trash the Preferences.
It will also restore your user settings afterwards.
Download:
https://www.macupdate.com/info.php/id/14729>Then, start again at my “step 1” above.
And, you should always MIXDOWN your audio before you play your sequence.
First, SELECT ALL of your audio tracks (highlight them) on the timeline, then:Sequence Menu > Render Only > Mixdown.
This can help with all kinds of “sticking” playback problems, audio and/or video.
