Activity Forums Apple Final Cut Pro Legacy Log and Capture with offset
  • Log and Capture with offset
    Posted by Russell on November 29, 2006 at 12:34 am
    Greetings!
    Due to an error at my post facility, all my dailies are out of synch by 2 frames.
    I am planning to capture the takes, then fix the synch, then export them again as Quicktime movies, then update the timecode manually based on the window burn.
    I’m wondering though: Is it possible to capture with an offset so I do not have to go through this process?
    Any help would be much appreciated!
    Best regards,
    Russell
    Final Cut Pro HD 4.5
    Mac OS X 10.4.5
    Jerry Hofmann replied 19 years, 10 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    November 29, 2006 at 2:31 pm
    Is the source an audio/video clip or is it a Dat machine or other audio only capture?
    You can’t capture with an offset, however you can change the timecode on any captured clip if that would help. If the source is audio/video then it should be able to be recaptured in sync.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
