Activity Forums Apple Final Cut Pro Legacy log and capture window size
  • log and capture window size
    Posted by James Roche on September 16, 2005 at 2:45 pm
    Sometimes my log and capture window is tiny and sometimes its big, but I cant find where in the FCP menu’s to control the size? I tried expanding it with the mouse but that doesn’t work. How do you do it?
    thanks
    jimmy
    Shane Ross replied 21 years ago 5 Members · 6 Replies
  • Shane Ross
    September 16, 2005 at 3:01 pm
    You can’t adjust the size. As for why it sometimes is one size and sometimes another is odd. It has always been the same size for me.
  • Bret Williams
    September 16, 2005 at 3:15 pm
    It’s the size of your canvas window I believe.
  • Don Greening
    September 16, 2005 at 3:44 pm
    James,
    Before you open the log and capture window go to: window/arrangement/two up. Now when you open log and capture the window will be a bigger size.
    – Don
  • Bret Williams
    September 16, 2005 at 6:21 pm
    Simply because the Canvas window is now larger. The capture window is either 50% or 100%. Depending on the size of your canvas window. The actual size. Not the % listed in the window. For example, if you have your canvas window filling the screen, but are viewing material at 50%, then the capture window will be at 100%.
  • Deditster
    September 16, 2005 at 8:36 pm
    it depends on what size you make your viewer. if you want a big log & capture make your viewer bigger. you can ajust it.
  • Shane Ross
    September 16, 2005 at 10:27 pm
    Well. YOu learn something new every day.
    Please excuse my misinformation.
