Activity Forums Apple Final Cut Pro Legacy Log and Capture reporting T/C breaks when there are none…
  • Log and Capture reporting T/C breaks when there are none…
    Posted by Ben Wharton on September 6, 2006 at 6:09 pm
    Being fairly new to FCP I’m not sure if this is a software or hardware issue.
    i.e. digitising from an HDV deck – the lowely HVR-M10E – FCP 4.5 on 10.3.9 is sometimes “inventing” T/C breaks for no apparent reason.
    Is this a “feature” of the lovely Log and Capture app or is it a function of the cheap as chips deck? Or could it be a dodgy firewire cable?
    Any pointers greatfully received!
    Thanks.
    Ben
    Ben Wharton replied 19 years, 12 months ago 2 Members · 2 Replies
  • Aaron Neitz
    September 6, 2006 at 9:46 pm
    Don’t know about your HDV problem specifically, but try 1) re-tensioning the tape 2) reading LTC instead of VITC
  • Ben Wharton
    September 6, 2006 at 11:33 pm
    HI Charlie
    Thanks for the reply. It’s happening on more than one tape – not that often, but often enough for it to be a pain – esp on multi camera set-ups.
    Where does reading LTC instead of VITC come in? The deck or in FCP?
    And does the above mean that FCP doesn’t do this kind of stuff normally?
    Thanks.
