Activity › Forums › Blackmagic Design › Log and capture problems using FCP7, HDW2000 deck and Multibridge Pro.
  • Log and capture problems using FCP7, HDW2000 deck and Multibridge Pro.
    Posted by Brenda Delv on October 20, 2010 at 11:16 pm
    Hi.
    I have a movie that was shoot with the Sony F900, I whant to transfer the footage to my computer for editing.
    I am using Multibridge pro 2, Mac Pro Two 2.4GHz Quad-Core Intel Xeon “Westmere” processors and Sony HDW-2000 deck.
    I have everything connected, I can see the image on a monitor connected to the deck and I can manipulate the deck from my computer, but I CAN NOT SEE THE IMAGE ON THE LOG AND CAPTURE WINDOW FROM FCP7 and therefore I can not capture anything.
    I connect the deck to Multibridge via SDI, and also using a 9-pin plug, as explained in the Multibridge manual.
    My setups is as follows.
    BLACKMAGIC SETUP:
    SET AOTPUT: SDI & HDMI & Composite & component
    SET INPUT: SDI VIDEO & AES/EBU AUDIO.
    FINAL CUT SETUP:
    Easy setup: FORMAT: All formar. RATE: All rate. USE: Blackmagic HDTV 1080p 24 Apple Pro-Res (HQ)
    Please I need help I try a thousand ways and I can not get it. Sorry for my English, my first language is Spanish.
    Thank You.
    Brenda.
    Brenda Delv replied 15 years, 11 months ago 2 Members · 2 Replies
  • Kristian Lam
    October 22, 2010 at 4:04 am
    Is it really 24p or 23.98p? If it is 23.98, then choose the 1080p23.98 easy setup in FCP.
    regards
    Kristian Lam
    Blackmagic Design
  • Brenda Delv
    October 24, 2010 at 6:26 pm
    The deck can read the tape in 24 but when trying to capture the image appears for a second then disappears, comes and goes constantly. The same in 23.98 easy setup.
