Activity Forums Apple Final Cut Pro Legacy Log and Capture Problem
  • Log and Capture Problem
    Posted by Craig Bass on June 7, 2010 at 6:26 pm
    Having a major problem with Final Cut 6 log and Capture: something I have never seen before.
    When I put a tape into the camera and then call up the Log and Capture window, all looks well and fine. When I hit play in Log and Capture, the tape begins to roll along with the timecode. However, the instant I hit “capture now”, the tape continues to play, but the timecode ceases and nothing is captured.
    If I attempt to log the tape first, and then capture it, I run into the same issue.
    All of my settings are correct. I have attempted multiple tapes on two different cameras, and end up with the same results.
    I am using a Canon XH-A1, and a Sony FX-100. I am running a PowerMac with a Dual-Core Intel and 10 GB of RAM. Current operating system is 10.5.8.
    Log and Capture worked just fine yesterday.
    Any ideas as to what is going on?
    John Fishback
    replied 16 years, 3 months ago
    2 Members · 1 Reply
  • John Fishback
    June 7, 2010 at 6:46 pm
    When the unexpected happens I always trash prefs, repair permissions, and run Disk Warrior.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
