Activity Forums Apple Final Cut Pro Legacy log and capture issues
  • log and capture issues
    Posted by Scott Maida on May 12, 2011 at 5:09 am
    when attempting to ingest from my DV deck, I get an error..
    “capture encountered a problem reading the data on your source tape. This could be to a problem with the tape.’
    it then… to capture as much of your footage as possible… please capture a clip that ends befre this segment and another one that starts right after it.
    not sure what that means.. but I was able to play the tape and log.. but the batch didn’t work either.
    Suggestions? I have not yet figured out the camera connection and will try that as well.
    Tape is miniDV SD… deck is panasonic AG-DV2500
    Scott Maida replied 15 years, 4 months ago 2 Members · 2 Replies
  • Dave Johnson
    May 13, 2011 at 8:26 pm
    Could there be timecode breaks on the tape that are preventing it from batch capturing? If so, just do a crash capture (play the tape and hit “capture now” instead of logging ins and outs for batching).
  • Scott Maida
    May 13, 2011 at 8:38 pm
    Turns out, it wasn’t a time code issue, I changed the setting from DV50 to DV and it worked. It was not reading the data from the deck nor cam.
    and I had to change the audio from 48 to 32 as well.
    Thanks though!
