Activity › Forums › Apple Final Cut Pro Legacy › Log and Capture is giving a HUGE image
  • Log and Capture is giving a HUGE image
    Posted by Justin Vernon on August 16, 2006 at 3:10 am
    I am capturing footage from an uncontrollable device and the resulting clip is HUGE. So big that when increasing the viewer window to the entire screen of my monitor I still can only see half of the clip. I’m wondering what setting I can modulate to get an un-zoomed image??
    Justin
    Brooklyn, NY
    Justin Vernon replied 20 years, 1 month ago 2 Members · 4 Replies
  • Richard Harrington
    August 16, 2006 at 12:23 pm
    Make sure your easy setup matches your tape format.. then switch it to non-controllabel device before capturing
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors, Understanding Adobe Photoshop, and ATS:iWork
  • Justin Vernon
    August 17, 2006 at 4:28 am
    When you say ‘tape format’ what exactly do you mean? Because I just made sure the easy setup was the same as the format in the Capture/Input drop down within the Log and Capture window and WALAH, that crazy oversized image is still happening.
    August 18, 2006 at 2:59 am
    If you are capturing DV set it to DV… etc.
    You have given us WAY too little info
    What video source are you trying to capture
    What video tape is it coming from
    etc.
  • Justin Vernon
    August 18, 2006 at 5:50 am
    The viewer was set to 400% can you believe it?
    Justin
    Brooklyn, NY
