Activity › Forums › Apple Final Cut Pro Legacy › Log and Capture is adding an extra “B” at the end of clip name
Posted by Dan Fredley on July 8, 2007 at 12:31 pmDoes anyone know how to get rid of the “B” that FCP keeps adding to my clip name?
Thanks.
Bob Flood replied 19 years, 2 months ago 5 Members · 6 Replies -
Walter Biscardi
July 8, 2007 at 12:46 pmHave never seen FCP add anything to a name except sequential numbers.
Walter Biscardi, Jr.
HD Editorial & Animation for Broadcast and independent productions.All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! https://blogs.creativecow.net/WalterBiscardi
Gary Adcock
July 8, 2007 at 1:15 pm[walter biscardi] “Have never seen FCP add anything to a name except sequential numbers.”
nah
it is smart enough to have done lettering since v 2 also.gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows -
Walter Biscardi
July 8, 2007 at 4:34 pm[gary adcock] ”
nah
it is smart enough to have done lettering since v 2 also.”But adding an extra “B” at the end of the clip name? What would cause that?
David Roth weiss
July 8, 2007 at 5:03 pm[walter biscardi] “But adding an extra “B” at the end of the clip name? What would cause that?”
That would probably be putting an “A” at the tail of the previous clip name.
Walter Biscardi
July 8, 2007 at 5:10 pm[David Roth Weiss] ”
That would probably be putting an “A” at the tail of the previous clip name.”I guess if you put an A at the end of every clip name, then yes, that would certainly do it. never thought of that.
Bob Flood
July 9, 2007 at 2:09 pmHi
the only time i have seen fcp add a Letter (as opposed to incrementing numbers) is on the REEL name, and its usually because of time code breaks ie i set an in and out on a tape to capture, but there is a tc break between that in and out, so fcp stops, recues before the break, then captures after the break, but adds a B suffix to the reel name or number.
its actually a good way to keep track of clips that might not recapture correctly.
depending on the number of breaks, it will add C, D, E, and so on.
after the stuff is all captured, you can go into the bin, select the clips that have been B-ed, and change them back to the original number, if you like.
you can also leave them
i know this may sound like a shill to buy more storage, but i have found that its a real thrash to recapture in FCP, especially with a prosumer deck like M10U (which we have)
I always capture at the resolution i am going to finish at, so i do not need to recapture or if i do, its a minimum amount of material.hope this helps
bee eph
