Activity Forums Avid Media Composer Log and Capture in Xpress, edit in composer…
  • Log and Capture in Xpress, edit in composer…
    Posted by John Collins on May 7, 2008 at 9:21 pm
    Im wondering if I can log and capture footage(offline 15:1) in Avid Xpress, then open the project in Media Composer on a different computer, with the captured footage(in OMF folder) on a firewire drive, and have everything reconnect fine? Also, with all my project settings, bins, sequences, upgrade to Composer? I don’t want to re-capture the media in Composer, so Im hoping moving the OMF file on a firewire will do the trick. Any thoughts on this workflow would be great.
    Jon Zanone replied 18 years, 4 months ago 2 Members · 1 Reply
  • Jon Zanone
    May 8, 2008 at 11:33 am
    There’s no reason it shouldn’t work. If you are upgrading, I would back up everything in your project file to a seperate disk and store if far from your CPU. That should keep the edit gremlins confused just long enough.
    Jon
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
