Activity › Forums › Apple Final Cut Pro Legacy › Log and Capture IMX50 with Kona3 Issues
  • Log and Capture IMX50 with Kona3 Issues
    Posted by Matt Tureck on March 4, 2011 at 8:03 pm
    Hi folks,
    Just upgraded the AJA Control panel to 8.1 using a Kona 3 card with fully updated system software/FCP.
    I can’t Log and Capture using the IMX50 codec anymore…it’s no longer recognized. Worked fine with AJA 7.3.
    Any ideas?
    Paul Jay replied 15 years, 7 months ago 3 Members · 4 Replies
  • Paul Jay
    March 5, 2011 at 4:59 pm
    Have you installed the extra codecs/settings?
    When you install AJA drivers a lot of formats are deselected by default.
    If not, you can always edit a 10 Bit uncompressed preset in Audio/Video settings.
  • Matt Tureck
    March 5, 2011 at 7:00 pm
    I haven’t installed the extra codecs…how do you do that?
  • Andy Mees
    March 6, 2011 at 2:52 am
    You shouldn’t ned to install extra codecs Matt, the IMX50 codec is installed as part of your FCP install. I think what Paul is suggesting is just that by default AJA may no longer install Easy Setups / Capture Presets etc for all formats … you can create your own by simply duplicating and modifying an existing preset (duplicate the existing AJA Uncompressed 8-bit capture preset, then edit the duplicate and change the Compressor to IMX50) or perhaps there is an option in the latest AJA installer to install additional presets.
    Cheers
    Andy
  • Paul Jay
    March 6, 2011 at 6:10 pm
    Run the AJA installer again and you will see.
