Activity › Forums › Apple Final Cut Pro Legacy › Log and capture
Log and capture
Posted by Michael Allen on July 12, 2005 at 1:16 pmIs there and abort command while capturing? Or do I end capture and delete the unwanted clip. The other system that I use does have an abort command. Does FCP have this feature???
Walter Biscardi replied 21 years, 2 months ago 2 Members · 3 Replies -
Walter Biscardi
July 12, 2005 at 1:59 pmPress ESC during capture. You may want to read up in the manual about the capture process.
Walter Biscardi, Jr.
Creative Genius, Biscardi Creative Media
https://www.biscardicreative.comNow in Production, “The Rough Cut,” https://www.theroughcutmovie.com
Michael Allen
July 12, 2005 at 2:01 pmYou may want tto read before you post. I did not ask how to stop the capture process, I asked if you can abort the capture and not make a clip to be deleted and not use drive space. Abort like the functonality of M100.
Walter Biscardi
July 12, 2005 at 2:04 pmAs far as I know, there’s no way to force FCP not to keep the clip if you are doing a Capture Now.
During a Batch Capture, if you abort the process, the clip is not saved.
