Activity Forums Maxon Cinema 4D loft nurbs to spline?
  • loft nurbs to spline?
    Posted by Paul Sullivan on May 25, 2005 at 7:09 pm
    Is it possible to somehow generate a spline from a loft nurbs in c4d? I want to make an object move along a loft nurbs I have made.
    Paul Sullivan replied 21 years ago 3 Members · 3 Replies
  • Brian Jones
    May 25, 2005 at 10:35 pm
    sure, make the loft editable (or do a Current State to Object) – in edges mode select the edge you want to follow – choose Structure/Edit Spline/Edge to Spline
    This assumes v9. If you are working pre-9 there was a plugin to turn edges to splines (but I don’t remember which it was).
  • Adam Trachtenberg
    May 26, 2005 at 11:59 am
    You can also project a spline onto any object. Structure>Edit Spline>Project
  • Paul Sullivan
    May 28, 2005 at 7:35 pm
    Thank you Brian and Adam that’s very useful
