Activity Forums Adobe After Effects Locking POSITION only
  • Locking POSITION only
    Posted by Eric Chard on May 14, 2009 at 7:12 pm
    I’m working w/masks and as usual am occasionally f’ing up and moving the layer rather than a mask node.
    Is there a way to lock the position of the layer w/o having to lock ALL the animatable attributes? That is, how can I pin the layer down while still editing mask nodes?
    “Putting the HARM in ‘harmonica’ since 2005.”
    Matthew Roberts replied 7 years, 6 months ago 4 Members · 7 Replies
  • 7 Replies
  • Todd Kopriva
    May 14, 2009 at 7:26 pm
    Two ideas:
    Set an expression on your Position property that defines it as a constant value.
    OR
    Don’t work with a mask on the layer. Work with a mask on a solid layer above the locked footage layer.
    I describe the latter approach a bit in a blog post about rotoscoping, in which I also recommend the Pete O’Connell Creative COW DVD on rotoscoping. (Pete uses this method, too.)
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
  • Eric Chard
    May 14, 2009 at 7:30 pm
    Thanks, intriguing ideas.
  • Eric Chard
    May 14, 2009 at 7:45 pm
    Using the eyeball switch makes it very hard to select the mask nodes (it deselects the mask), I think I’ll try using OPACITY at a very low level instead.
  • Todd Kopriva
    May 14, 2009 at 7:46 pm
    Here’s a link to the feature-request/bug-report form.
  • Eric Chard
    May 14, 2009 at 7:54 pm
    Yeah, because of the particular nature of the POSITION attribute, and the way the user interacts with masks being ambiguous to the application, locking POSITION out would be nice.
    I’m on AE7, so a little behind the times…
  • Curious Turtle
    May 15, 2009 at 9:25 am
    Take a look at this script, this should do the job for you.
    Cheers,
    Ben
    Curious Turtle Professional Video
    Training | Editing |Support
    http://www.curiousturtle.com
    Just out: Rock Steady : Successful Motion Tracking in Mocha & After Effects
  • Matthew Roberts
    February 19, 2019 at 3:06 am
    add this expression to your position property – courtesy of Mark Christiansen
    [width/2, height/2]
    Matthew Roberts
    https://kupon.co.uk/
    https://dribbble.com/matthewkupon
