Activity Forums Adobe After Effects locking only shy layers
  • locking only shy layers
    Posted by Kari Pieskä on May 10, 2013 at 8:33 am
    Is there a possibility to lock only shy layers?
    I have a rig and sometimes I accidently push a button that brakes the expressions between layers. Even though I use ctrl+z, it doesn’t bring the expression alive again. I have to open up all the layers I don’t need when animating, unlock them, select all and press U to see what expression is deactivated.
    After this I have to lock all the layers, one by one to get back to the position I was earlier.
    But, normally the layers that are shy, are the ones that are locked. So It would make some sense to me to have an option to lock only shy layers, wouldn’t it?
    Fernando Thomé replied 6 years ago 3 Members · 4 Replies
  • Ridley Walker
    May 10, 2013 at 9:45 pm
    I’ve written a script to do just that. It’s fairly crude but its effective. There are better scripts at aescripts.com, Zorro the Layer Tagger comes to mind.
    If you’d like, here is the script. I assume no liability.
    5987_lockshylayers.jsx.zip
  • Kari Pieskä
    May 13, 2013 at 9:48 am
    I also think this could be a nice little thing. Thank you for your responses, I’ll post adobe and also check if Ridleys solution might work for me.
  • Ridley Walker
    May 13, 2013 at 10:27 pm
    Kari;
    I cleaned up the code and made it a dockable panel. Put this new script in the ScriptUI panels folder and access it from the window menu.
    5992_lockshy.jsx.zip
  • Fernando Thomé
    August 7, 2020 at 7:29 pm
    Its been years since ive started using cretive cow… this is the firt time im replying. This sir is GOLD!!!
    thanks!
