Activity › Forums › Adobe After Effects Expressions › locking keyframes to markers ?
Posted by Alex Dinnin on July 24, 2008 at 3:07 pmHey everyone,
Is there a way I can lock keyframes to a marker ???
I have loads of maps to make, all the same format.. however the keyframes have to move.. eg map 01 has layer 01, 02 & 05 have scale, opacity and position keyframes at 12 & 120, and on map 02 they have the same keyframes but at 15 & 97.
What would be great. would be to constrain all the keyframes to markers.. so at every map.. instead of having to twiddle down each layer.. I could just move two markers ??
is this even possible, or am I being a bit optimistic ??
thanks in advance
Alex
Raja kamaruzzaman Rc replied 9 years, 4 months ago 5 Members · 14 Replies -
Matthew Tully
July 24, 2008 at 4:39 pmyou should make a null and attach as many sliders as you have properties to change each time, this way you only have to edit one set of keyframes.
Not sure if this helps, could you explain the problem a little more?
Dan Ebberts
July 24, 2008 at 4:44 pmAssumptions: Each map is its own comp; the map comps are all in another comp named “master”; there are exactly two linear keyframes for each keyframed property; the markers are applied to the map comp layers in the master comp; the map comp layers in the master comp have not been renamed. Then, applying this expression to each keyframed property should do the trick:
L = comp(“master”).layer(thisComp.name);
if ((L.marker.numKeys > 1) (&& numKeys > 1)){
t1 = L.marker.key(1).time;
t2 = L.marker.key(2).time;
v1 = valueAtTime(key(1).time);
v2 = valueAtTime(key(2).time);
linear(time,t1,t2,v1,v2)
}else{
value
}If your setup is different, the expression will need to be revised. 🙂
Dan
Alex Dinnin
July 24, 2008 at 8:52 pmok.. Thanks for the help so far.. but I don’t think I really explained myself.
I have a big resolution map, which I have a route going from A to B, using stroke. I have a triangle following the stroke (copied the path onto the position) to look like a pointer. As the Pointer gets near to B the name appears. I then precomp this into a Pal 16:9 comp which I animate the position.this is basically the run down.
frame 10 : stroke starts, triangle starts.
frame 100 : place name opacity 0%
frame 110 : place name opacity 100%, end stroke.
the durations of the maps change.. some are 90 frames some are 120 etc etc.. however the setup is always the same. The first keyframe is at 10 frames.. What I want to be able to do is have a marker which the end two keyframes follow.
I have about 80 of these maps to do, so it would be fantastic if I could just move two end markers.. and the end keyframes follow..
I hope this makes a bit more sense..
thanks for your help already
regards
Alex
Dan Ebberts
July 24, 2008 at 9:40 pmOK – now assume that you have a layer in the comp named “Layer With Marker”, where the marker is. Then try this:
L = thisComp.layer(“Layer With Marker”);
if ((L.marker.numKeys > 0) && (numKeys > 1)){
t1 = key(1).time;
t2 = L.marker.key(1).time;
}else{
value
}Dan
Alex Dinnin
July 25, 2008 at 11:26 amHi Dan,
Thank you so much.. It took me a while to work out how it was working.. and then a bit longer to tweak it..
But it works like a charm now.. thanks very much for you help
Alex
Ali Asgari
August 22, 2015 at 3:47 pmdear friend
I have similar problem
I’m working on a project and I have to import many sequences with own markers from primiere to after effects . I want to camera keyframe change to marker automatically . I tried to change your expression and change it for my project but I failed . may you help me .
thanks in advance and sorry for my bad english -
Alex Dinnin
August 22, 2015 at 6:00 pmI’m sorry. I don’t really understand what you Nader to do.
Could you try and explain a bit more ?
Ali Asgari
August 22, 2015 at 9:01 pmI want to my camera keyframe position move base on markers of a layer .
your expression worked finally with two keyframe. I tried to change and adopt it for more than two keyframe. but I got warning .
I changed your expression this wayL = comp(“master”).layer(thisComp.name);
if ((L.marker.numKeys > 1)){
t3= L.marker.key(3).time;
v3= valueAtTime(key(3).time);
linear(time,t1,t2,t3,v1,v2,v3)
}else{
value
}and I got attached warning.
many thanks for your help.<a href="https://images.creativecow.net/300638/attachment.jpg"><img src="https://i1.creativecow.net/u/300638/attachment.jpg" border="0" /></a> -
Dan Ebberts
August 22, 2015 at 9:38 pmlinear() only works for two values. I think you need something more like this:
L = comp("master").layer(thisComp.name);
if ((L.marker.numKeys > 2) && (numKeys > 2)){
if (time < t2){
linear(time,t1,t2,v1,v2);
}else{
linear(time,t2,t3,v2,v3);
}else{
value
Dan
Ali Asgari
August 23, 2015 at 7:33 amyou are great
it worked .
many thanks.
and can I expand the expression for more key frames?
