Activity Forums Adobe Premiere Pro Lock-up EVERY time.
  • Lock-up EVERY time.
    Posted by Gerry Bayne on June 3, 2010 at 11:18 pm
    Here are the specs to my machine:
    Dell Studio XPS 435T
    Intel Core i7 CPU
    12GB RAM
    64-bit
    NVIDIA GForce GTS 240
    I’m fine when using Adobe After Effects. It works great. But when I try
    to edit ANYTHING in Premiere Pro, it locks up within the first 3 minutes of working. It usually happens when I go to put an effect on the timeline.
    I have tried everything and I just cannot figure out how to get this thing to run smoothly. I make sure all my media files are on the other partitioned drive. I make sure to close all other programs. I don’t know what else to do.
    My 8-cores barely blip when I’m using the program, so I don’t think it’s a matter of taxing the system.
    Any help would be a godsend.
    Rick Connolly replied 16 years, 3 months ago 3 Members · 3 Replies
  • Jeff Pulera
    June 4, 2010 at 2:45 pm
    Hi Gerry,
    What is your hard drive setup? All video clips should go to a separate physical drive, not on C: or a “partition” of C.
    What video format are you working with, and what is the Premiere project preset you are using?
    Is this CS5?
    Jeff Pulera
    Safe Harbor Computers
  • Gerry Bayne
    June 7, 2010 at 6:09 pm
    Hi Jeff-
    I was working with AVCHD and .mts files. I rendered them down to various lower non-HD formats, thinking that might help. I rendered them as windows media, avi, QT, all still locked up.
    I am using Adobe CS4.
    Thanks for any advice.
    -Gerry
  • Rick Connolly
    June 10, 2010 at 7:32 pm
    Gerry,
    Click on my name and follow my links on crashes. I had the same problem as you.
    All problems went away once I changed my video card to one of the approved cards.
    I have not had a lock up since.
    Rick
