Activity Forums VEGAS Pro lock track
  • lock track
    Posted by John Culleton on January 7, 2008 at 12:49 pm
    i have a VO track cut into sections, how do i lock the track? i also want to normalise the track, i’m looking for a single keystroke instead of selecting all the clips. maybe a script?
    Hank Snider replied 18 years, 6 months ago 4 Members · 8 Replies
  • 8 Replies
  • Edward Troxel
    January 7, 2008 at 3:13 pm
    You don’t lock a track. You *can* lock all of the EVENTS on that track.
    Normalizing can be done via a script. You can also just select all the events, go to Edit – Switches and pick Normalize. However, be aware it may not really give you the results you’re looking for!
    Edward Troxel
    JETDV Scripts
  • Douglas Spotted eagle
    January 7, 2008 at 3:20 pm
    Edward is correct, of course, you can’t lock a track in Vegas, you may only lock events found on a track.
    However, the industry term “Locked track” is common, and many NLE’s offer the ability to lock a complete track at the header.
    This has been requested for Vegas in the past.
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
  • John Culleton
    January 7, 2008 at 3:25 pm
    so i ‘select events to end’ and use everything in ‘switches’ right?
    January 7, 2008 at 3:34 pm
    Right click first event, hit the “N” key, then right click again, and choose Switches/Lock.
    VASST
  • John Culleton
    January 7, 2008 at 3:49 pm
    thats more like it, where do i find more of those then? don’t see it anywhere in the keyboard shortcuts
  • Hank Snider
    March 24, 2008 at 12:42 pm
    I find the ability to lock events quite useful, but it would be better to bind a keyboard shortcut to it. Bad news, because it doesn´t work for me. Non of the choosen keyboard shortcut works for locking an event.
    Is this a bug in Vegas (8)?
  • Edward Troxel
    March 24, 2008 at 5:43 pm
    Hank, you can use a script to lock an event. In fact, the script could TOGGLE the lock switch (lock it if it’s unlocked and unlock it if it’s locked). Scripts can be easily assigned to a keypress so what you want to do can easily be done.
    Edward Troxel
    JETDV Scripts
  • Hank Snider
    March 25, 2008 at 10:01 pm
    Thanks Edward, after saving the key bindings to a new file it worked!
