Activity Forums Adobe After Effects Lock Scale within an expression
  • Lock Scale within an expression
    Posted by Anthony Sipsas on February 26, 2013 at 7:24 pm
    I am relatively new to scripting and am looking for a means to lock both parameters of a scale expression to equal each other, so that even though there is a random value assigned, x dimension= y dimension for every value given.
    I current have the following in the scale parameter:
    ease(time,wiggle(.5,2.7),wiggle(.5,2.7))
    Which results in separately generated values for the x,y. Is it possible to get whatever values generated by this to provide a single value which is applied to both the x and y?
    Based on my math experience from 10 years ago (need refresher courses), I am assuming that this may get it:
    x=ease(time,wiggle(.5,2.7),wiggle(.5,2.7));
    [x,x]
    Would that be correct, can’t get that to work. I am assuming its syntax.
    Darby Edelen replied 13 years, 6 months ago 4 Members · 4 Replies
  • John Cuevas
    February 26, 2013 at 7:53 pm
    By wiggle generates values for both X and Y, that’s why you are getting the “array piece can’t expand to more than one value” error…IE, in your expression when you say wiggle, it’s comes up [2,7] which you are defining as X. You are then trying to make a scale paramter of that is this [2,7, 2,7].
    So you need to tell AE, to just use one of the parameters, in your case, the first one. Here’s how it should look:
    x = ease(time,wiggle(.5,2.7),wiggle(.5,2.7))[0];
    [x,x]
    The [0] tells AE to use the first value produced by the wiggle(AE starts with 0 as the first index number). You could use [1] to get the second or if you had a Z space [2].
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Kevin Camp
    February 26, 2013 at 7:57 pm
    since wiggle works on multidimensional properties, you’d just need to specify the index of the dimension that you want to use.
    also, i don’t think you need the ease() function with wiggle (it already has smooth interpolation).
    try this:
    s = wiggle(.5,2.7)[0]
    [s,s]
    — john beat me to it
    — and i forgot a semicolon after the first line
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Anthony Sipsas
    February 26, 2013 at 8:08 pm
    Thanks, Guys, i kept messing with it, but didn’t get it to work until i did the following:
    x=(ease(time,wiggle(.5,2),wiggle(.5,2)));
    [x[0],x[0]]
    I guess i was missing the “[0]”
    is there a “dictionary” so to speak for expressions in AE so I can at least make sure my syntax is written in a means that AE can understand?
  • Darby Edelen
    February 26, 2013 at 8:40 pm
    [Anthony Sipsas] “is there a “dictionary” so to speak for expressions in AE so I can at least make sure my syntax is written in a means that AE can understand?”
    It’s JavaScript with included AE specific functions as defined here:
    https://help.adobe.com/en_US/aftereffects/cs/using/WS3878526689cb91655866c1103906c6dea-7a0ca.html
    Darby Edelen
