Activity Forums Adobe After Effects “Lock” Precomp?
  • “Lock” Precomp?
    Posted by Tyler Ammons on October 22, 2017 at 12:25 am
    Hi! I was wondering if there is a way to “lock” a precomp so that after effects wont continue to try to render it all over, and just keep whatever you have. For example, I am working on a 3d track with text, that I am making reflective and using an environment layer. I have about 4 shots like this, and every time I edit one, after effects has to re-render every other one which is extremely slow. Is there a way to tell ae to just keep whatever it has for the ones im not actually editing so it doesnt have to recalculate everything?
    Roei Tzoref replied 8 years, 11 months ago 3 Members · 4 Replies
  • Roei Tzoref
    October 22, 2017 at 12:34 am
    not sure I understand. are the precomps being rendered in the scene? if you don’t want them to render then turn the eyeball switch off or set opacity to 0…
    Roei Tzoref
    2D/VFX Generalist & Instructor
    ♫ AeBlues Tutorials ♫
    http://www.tzoref.com
  • Tyler Ammons
    October 22, 2017 at 1:05 am
    Sorry, I mean I have 3 precomps now, each contains the extruded text, camera, light, and environment layer. But sometimes, when I make a change to the main comp, Ae has to re calculate all the raytracing for each of the text layers inside their own precomps. Is there a way to almost turn the text into a rendered video layer that Ae doesnt have to recalculate every time?
  • Walter Soyka
    October 23, 2017 at 4:59 pm
    Either pre-render as Dave mentioned, or use Keen Live [link]
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Roei Tzoref
    October 26, 2017 at 10:36 pm
    [Walter Soyka] “Although people usually think of proxies as low-quality stand-ins for real footage, there’s no reason why you can’t use high-quality proxies. I prefer this to pre-rendering because it gives an easy switch in the project panel for turning a comp’s proxy on or off; just make sure you change your render settings Proxy Use to “Current Settings” for the speed boost during render.”
    this is exactly what I do. with complex and heavy projects I use HQ proxies and render my project with them when I am done. and I also have current settings for all my renders.
    Roei Tzoref
