Activity Forums Adobe After Effects “lock” position of a mask
  • “lock” position of a mask
    Posted by Stephan Dube on April 4, 2008 at 1:02 am
    Hello
    Im a new user of After FX, I believe my question should be fairly easy…
    I woudl like to know how do you “lock” the position of a mask?
    What I am trying to do is to move a layer around but keep the mask on the same place. now when I move a layer with a mask the mask follows it.. I want to “lock” the mask position…
    Any thoughts?
    thanks
    cheers
    Marianna Rudakova replied 9 years, 5 months ago 4 Members · 4 Replies
  • Curious Turtle
    April 4, 2008 at 6:19 am
    Hi Stephan,
    You want to use a track matte.
    Create a mask on a solid layer that lies on top of the layer you want to cut out. Then click on the TrkMatte dropdown menu on your footage layer, select Alpha Matte.
    Here’s the layer order for you:
    1) Masked solid
    2) Your footage – Track matte set
    3) Background (if used)
    Now you can move your footage layer around and the mask won’t move.
    Hope that helps,
    Ben
    Curious Turtle Professional Video
    Training | Editing |Support
    http://www.curiousturtle.com
  • Stephan Dube
    April 4, 2008 at 9:36 pm
    dude thanks so much.. it works like a charm 🙂
    cheers
    Stephan
  • Matthew Gaunt
    January 20, 2013 at 10:09 pm
    I had exactly the same question and it worked perfectly! Thanks so much for your crystal clear answer.
    Cheers, Matt
  • Marianna Rudakova
    April 20, 2017 at 11:08 am
    Thanks a lot!!!
